Freelander Talk about the Land Rover Freelander within.
rear seat stuck in down position
Old Dec 11, 2007 | 07:57 PM
qfergusonjr's Avatar
Default rear seat stuck in down position
anyone experience a problem in the freelander where the rear seat can't be raised after put down. any remedies?
Old Dec 12, 2007 | 02:15 PM
cvw_bandit's Avatar
Default RE: rear seat stuck in down position
Hi, I assume you've pushed the seat base release levers?
Old Dec 23, 2007 | 09:12 PM
05LandRover's Avatar
ORIGINAL: cvw_bandit
+1
Old Jan 29, 2008 | 04:32 PM
Patod's Avatar
Had the same issue. The base would go back ok, but the back would only goto 45 degrees.
the mechanism to engage the underhooks was getting jammed. It's located under the plastichinge cover in the center. remove it, and you will see the levers moving. the inner one was getting stuck. pushing it to the rear & it operated fine. a bit of greese appears to do the trick.
good luck if it's the same issue or anybody else who may come across it.
Old Jan 28, 2012 | 10:14 AM
freelandersardinia's Avatar
Same problem with my 03 freelander.....but I cannot find the inner lever!!
I need urgent help!! I have made some pics :see in attachments
please urgent!! it's my dad's car and I dont' want to make him angry!
Attached Thumbnails  rear seat stuck in down position-28012012278.jpg    rear seat stuck in down position-28012012279.jpg
Old Jan 30, 2012 | 08:44 AM
Rovin4life's Avatar
pull on the inner level from the back and push slightly on the side of of the latch. its designed to be done from the back. from the side and it pulls the seat slightly. you just have to push it back down a bit to get it in.
spanishfly
Mar 15, 2015 11:33 AM
Grover11
Dec 26, 2014 04:59 AM
ImQuattro
May 1, 2014 08:36 PM
ajs33
Feb 19, 2013 08:18 AM
RobRover
Jul 3, 2008 07:38 PM
