Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 07-16-2009, 08:50 PM
Junior Member
Default Land Rover Freelander Fault Codes p1161 and p2098
I have a 2004 Freelander SE with 72,000 miles on it. The check engine light has come on with the codes p1161 and p2098. I p1775 and p0705 were also on, but on subsequent readings those codes are no longer there. I believe that p1161 refers to the MAF sensor, but I have also seen that it could be "P1161 Fuel Trim Inactive Bank 2 High, depending on which manufacturer (BMW vs GM) you believe the code to be more similar too (I can't find any listing for Land Rover Codes). p2098 I think may be the o2 sensor, post catalytic converter, but I am not sure if it is the sensor or the wires that are triggering the code. Before I replace the MAF (200 dollars) and an o2 sensor (80 dollars) I had wanted to see if anyone can verify that this is infact what needs to be done since I can't seem to find Land Rover specific interpretations. Also, should I be worried about those other two codes, which I believe refer to the transmission.
Best regards,
Jonathan
Tags
2004, bmw, check, code, codes, diagnostic, engine, faults, freelander, land, light, p0705, p1775, p2098, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
