Freelander Talk about the Land Rover Freelander within.
Land Rover Freelander Fault Codes p1161 and p2098
Old Jul 16, 2009 | 08:50 PM
lordadmiral's Avatar
Default Land Rover Freelander Fault Codes p1161 and p2098
I have a 2004 Freelander SE with 72,000 miles on it. The check engine light has come on with the codes p1161 and p2098. I p1775 and p0705 were also on, but on subsequent readings those codes are no longer there. I believe that p1161 refers to the MAF sensor, but I have also seen that it could be "P1161 Fuel Trim Inactive Bank 2 High, depending on which manufacturer (BMW vs GM) you believe the code to be more similar too (I can't find any listing for Land Rover Codes). p2098 I think may be the o2 sensor, post catalytic converter, but I am not sure if it is the sensor or the wires that are triggering the code. Before I replace the MAF (200 dollars) and an o2 sensor (80 dollars) I had wanted to see if anyone can verify that this is infact what needs to be done since I can't seem to find Land Rover specific interpretations. Also, should I be worried about those other two codes, which I believe refer to the transmission.
Best regards,
Jonathan
FRLNDR
Freelander
Jun 8, 2014 09:35 PM
06Range
May 8, 2013 09:01 PM
Ninden
Freelander
Jul 23, 2009 01:15 PM
