Freelander Talk about the Land Rover Freelander within.
What should the fule Pressure be?
Old Feb 3, 2012 | 12:26 PM
Aff2010's Avatar
Default What should the fule Pressure be?
Have a 2004 Freelander V6. Checking fuell pressure and get 55lbs at idle and 52lbs under load. Anyone know what the correct fuel pressure is on this vehicle.
Thanks.
Old Feb 3, 2012 | 02:38 PM
3.2 bar or 46-47 PSI, so your fuel pump seems in order. If you take a few minutes, you can download the RAVE shop manual set below for free, is the complete factory manual package for your truck.
Old Feb 5, 2012 | 01:17 PM
Rovin4life's Avatar
Check your local dealer to make sure the fuel pump was installed under a recall. If it hasn't they will replace it for free. But its possible you have a lot more issues then just the fuel pressure.
seanyboy
Mar 4, 2013 03:56 PM
mtnaspen
Oct 24, 2011 02:36 PM
txt1
Sep 10, 2011 11:24 PM
captmec1
Jun 21, 2011 10:53 AM
klh113
Feb 21, 2008 10:18 AM
