Sponsored by: CARiD
engine problems
Old Jan 9, 2012 | 04:46 AM
bbear1998's Avatar
4th Gear
Default engine problems
hi i need some help deciding what to do my disco has blown the rear seal water goes in and out at the same time. now the question is to buy a reco motor or repair this one it has 330 k's on the clock any help would be gratefull
Old Jan 9, 2012 | 05:36 AM
By rear seal do you refer to water leaking down the back of the engine? Could be a head gasket. But if lucky, it could be valley pan. At your miles, engine can still be rebuilt. A manual oil PSI test will also indicate general condition of oil pump and perhaps pressure lost by worn lower end bearings. Compression test for rings.
Many write ups on this, incluidng in the truck replacement of lower end bearings, etc.
You can also get pull out motors at the junk yard, but you-pull-da-partz places usually have blown engines to start with.
Old Jan 9, 2012 | 07:37 AM
bbear1998's Avatar
4th Gear
ok thanku i have been offered a 2nd hand motor that has done 170,000 ks for $1000.00 with 3 mths warranty i think i might take it cheers
Old Jan 9, 2012 | 11:26 AM
Chris-bob's Avatar
That's what I paid for my entire Disco...
Old Jan 9, 2012 | 07:02 PM
Where exactly is it leaking from?
A blown head gasket is not a big deal.
Old Jan 10, 2012 | 07:12 AM
bbear1998's Avatar
4th Gear
We don't know as yet until I pull it out but the way the water was coming out I think the welsh plug blew cheers and thanku for your help
Old Jan 10, 2012 | 08:32 PM
You can replace the freeze plugs with new ones, it is common for them to rust and leak.
Old Jan 11, 2012 | 07:41 PM
bbear1998's Avatar
4th Gear
yeah i know and doing 330k's without changing them is not that bad but i will know more on the weekend when we pull it out cheers and thanku for your help
Frank4
Mar 21, 2014 05:21 AM
tcbinaflash
Jan 8, 2008 04:23 PM
Johnsy
Nov 26, 2006 06:07 AM
Roadrunner
Nov 9, 2006 12:03 AM
kipinomaha
Aug 21, 2006 02:11 PM
