Sponsored by: CARiD
Advice On Replacing Lower Control Arm Pls
Old May 7, 2013 | 03:23 AM
Judgey's Avatar
4wd High
Default Advice On Replacing Lower Control Arm Pls
Hi,
So at the weekend I hit a kerb/verge doing about 50mph, don't ask lol, and my passenger side lower control arm (wishbone thingy) is bent and is forcing my wheel into the wheelarch so it's not drivable.
I have had the wheel off and it looks like something I could tackle myself but I have a very limited toolkit so was wondering if anyone could tell me what tools I will need to do the job please and also if it's as simple as it looks? I was an mech engineer many many moons ago so can hold a spanner and work a hammer
Thanks in advance for any advice.
Cheers
Judgey
Old May 7, 2013 | 07:34 AM
roverguy7's Avatar
What model Land Rover do you have?
Old May 7, 2013 | 07:54 AM
Ditto, our Jedi powers are weak... but you can also downlaod the factory shop manuals, called the RAVE, and review the the needed practices. Rovers do bend, so it might be more than unbolt - bolt on. Between 2 and 3 tons of motivating object, striking a fixed spot. Math is not on your side.
Old May 7, 2013 | 09:36 AM
Judgey's Avatar
4wd High
It's a Freelander 2002 TD4 2L
Old May 7, 2013 | 10:25 AM
roverguy7's Avatar
Not sure on the diesels, but on the NAS ones it's pretty straight forward, worst part is lining it all back up under spring tension, but not bad.
Old May 8, 2013 | 08:25 AM
Judgey's Avatar
4wd High
Thanks for the info!
One final question...
I only have the jack that came with the car, do i need to buy a trolley jack & axle stands and if yes, where is best place to position them?
Cheers
Old May 8, 2013 | 10:31 AM
roverguy7's Avatar
Do not work on the vehicle with it only supported by the jack that came with it.
I recommend jack stands, as you will be pulling and hitting on the truck to get everything out and lined back up.
File Type: pdf
jft1428
Mar 22, 2018 10:25 AM
bmwrovers
Oct 23, 2014 04:08 PM
moorebl
Oct 3, 2014 09:59 AM
comleader
Mar 14, 2014 03:59 PM
matt5963
Jun 26, 2012 10:48 PM
