Sponsored by: CARiD
fuel pump relay
Old Dec 28, 2011 | 12:08 PM
SMOOTH OPERATOR's Avatar
4th Gear
Default fuel pump relay
Where can I find the fuel pump relay on the 94 Discovery
Old Dec 28, 2011 | 12:31 PM
large black box on the passenger wheel well area.
Why are you looking for it? There are 3 relays in side it.
Old Dec 28, 2011 | 08:10 PM
Relay - Fuel Pump | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
It is behind the passenger kick panel in the passenger cabin.
The relay Mike is talking about is for '96 and newer.
Old Dec 29, 2011 | 03:27 PM
4th Gear
I was told to try replacing relay before replacing fuel pump. Truck was running fine when I parked it it was parked for about a month when I try starting its just spinning over
Old Dec 29, 2011 | 03:29 PM
4th Gear
Does anyone have any suggestions on what I can check
Old Dec 29, 2011 | 06:17 PM
Start by checking the fuel pressure at the fuel rail, psi needs to be in the low to mid 30's.
Then check for spark.
If no fuel pressure replace the fuel pump relay.
Old Dec 29, 2011 | 07:54 PM
The relays are expensive and what you are describing is a bad pump, not the relay.
Old Dec 29, 2011 | 09:20 PM
His relay is $22 Mike.
Old Dec 29, 2011 | 10:01 PM
4th Gear
Thanks guys hopefully I will get it going I miss driving it
Old Dec 30, 2011 | 09:07 AM
Stand corrected, kept thinking his had the newer relay like the 96's.
They are expensive at $99.
bleizit
Jun 24, 2020 04:03 AM
Travelor
Sep 24, 2015 06:11 PM
RicketyTick
Jun 24, 2014 06:58 PM
coldstart
Mar 9, 2014 07:08 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
