Sponsored by: CARiD
Can someone please tell me your opinion??? 😩
Old Jun 26, 2022 | 05:57 PM
tabathajohnson36@gmail.com's Avatar
Default Can someone please tell me your opinion??? 😩
Can someone please give me their opinion… I have a 2014 Range Rover Sport. The other day I was driving when I noticed the D light was flashing on the dashboard and then my truck slowly started to shut down as I was driving, almost as if I ran out of gas (I had a full tank) so it was towed to a local shop. Not even 20 minutes later I get a phone call from the mechanic, which I thought was strange, but he tells me that the timing chain broke inside the engine, which then caused the pieces to seize and blew up the whole motor. My husband and I went by to check it out after we were told by others that what the mechanic said was highly unlikely. So my husband checks it out and sees the timing chain fully intact (pic attached) Now I have no clue whats wrong with it and why the mechanic would tell us that? Has anyone ever had this issue??? Or if there are any mechanics reading this, do you have any idea what it could possibly be? And would even be worth fixing??
Old Jun 29, 2022 | 07:04 PM
RoverDr's Avatar
So I will start with this. Has your truck made a rattle noise while starting cold ( like after its sits for a while) or any kind of noise prior to what happend? if so what happens is the tensioners wear into the chain guids and throws the timing off meaning absolutely the mechanic is correct. If no noises heard before then its unlikely to be the case. I have delt with this issue more then I can count. Feel free to ask any questions.
Jezzaron
Discovery Sport
Nov 21, 2022 08:18 AM
Jun 25, 2022 11:52 PM
Glider
Nov 14, 2020 02:15 PM
ljdiscovery
LR4
Aug 23, 2019 01:57 PM
arod829
Oct 10, 2012 12:08 PM
