Sponsored by: CARiD
headlight
Old Jan 22, 2012 | 02:18 AM
Fouts's Avatar
Default headlight
Low beam left front headlight out. high beams work on both headlights. I changed the sealed beam on the left and it didn't fix the problem. Any ideas why low beam front left would suddenly quit working and it not be a bulb problem? Thanks in advance
Old Jan 22, 2012 | 12:27 PM
So you changed the bulb on the left side?
Did you swap the bulbs to make 100% sure the bulb works and you didnt get a bad one?
What year and model do you have?
Old Jan 22, 2012 | 06:37 PM
Could also be a fuse, D1 uses separate ones for each side F4, F5, F10, F11. F22, F10, F9, F3 in a D2.
Old Jan 25, 2012 | 11:57 AM
WaltNYC's Avatar
One possible verbiage problem.....
There are four settings for the headlamps...
1) off - stalk is turned all the way toward the driver (call it "position 0")
2) "city lights" or parking lights as they are often known. stalk is clicked on position forward. Let's call this position #1
3) Low beams. Stalk is turned two clicks forward. call this position #2
4) high beams. Stalk is turned to position #2 and then lo/hi is selected by pulling back o the stalk.
Now, based on those definitions, which lights do and don't work?
Old Jan 25, 2012 | 03:14 PM
Yep, those city lights are ultra low beams for sure.
Old Jan 26, 2012 | 07:38 AM
Rovin4life's Avatar
you guys know without the year make and model it could be everything you guys haven't listed yet.
it could be a newer vehicle with alot more complicated stuff on it.
Old Jan 26, 2012 | 10:47 AM
Fouts's Avatar
Thanks for the replies! This is a 1992 Range Rover County. The high beams work and when set to the normal low beams position #2, the right front headlight works fine but the left headlight does not. If I push the stalk forward for "hi-beams" both lights work. I replaced the left sealed headlight with one from Napa, and the same thing happened.
Old Jan 27, 2012 | 08:48 AM
WaltNYC's Avatar
Rovin4life....you could be right. I thought I was in the D1 section of the forum for some reason. Brain fart
Fouts, my bad. What I wrote may not apply to you as I'm not too familiar with your vehicle. Please put your vehicle info in your 'signature' line so we can help more in the future.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
Henkman
Oct 14, 2005 02:48 PM
igriego
Jun 25, 2005 08:48 PM
