Sponsored by: CARiD
Wiring Diagram on Hella Trailer 7 pin connector
Old Oct 7, 2011 | 02:24 AM
ashtoo's Avatar
Default Wiring Diagram on Hella Trailer 7 pin connector
Does anyone out there have the diagram of the trailer wiring on 2001 RR 4.6HSE (US version) that has Hella european 7 pin connector?
The color of the wires are Brown, Black, Green, White, Red, Blue and Yellow (all are solid color no stripe color combination).
I need to know which wire does what.
I'm trying to hook the trailer wire converter (Hoppy Brand) that has 5 wires at one end (GREEN-Right Turn; YELLOW-Left Turn; BROWN-Tail/Park; RED-Brake; WHITE-Ground) and 4-flat connector at the other end (to hook on Uhaul trailer).
How can I splice 7-wires into 5-wires and make all the trailer lights works properly without giving any "wierd" warning on the dashboard?
Search everywhere, can't find same wiring color diagram in the forum
Any help would be greatly appreciate it. Thank you!
Old Oct 7, 2011 | 07:09 AM
Perhaps this will help. Not sure if exact year. You may be forced to use a volt meter to measure each wire to ground.
Pin numbers are on drawings, with wire color code.
Wire colors on drawings are:
 B - black
G - green
K - pink
L - "light"
N - brown
O - orange
P - purple
R - red
S - gray (slate)
U - blue
W - white
Y - yellow
File Type: pdf
File Type: pdf
Old Oct 7, 2011 | 11:41 AM
ashtoo's Avatar
Thank you!
The wire color chart and the PDF file are AWESOME!
...so I suppose the pin#4 on the C336 diagram is the bottom one in the socket right? (the one that has a "bump" on the socket)
Thank you again
Old Oct 7, 2011 | 02:45 PM
These come from the RAVE, your own copy awaits below. Download, and take out the versions for other Rovers you don't currently own.
gruehle
Jul 27, 2020 09:10 AM
parkerlander
May 31, 2014 11:59 AM
ebg18t
Jul 18, 2012 09:09 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
