Sponsored by: DashLynx
Hard Problem Starting When Cold???
Old 05-16-2010, 09:29 PM
BigDogg's Avatar
7th Gear
Question Hard Problem Starting When Cold???
My 1998 Range rover takes 3 or 4 tries with turning the key to the ON/Off position before it starts. It will run a little longer each time until about the 4th time when the start finally catches and keeps running. Also when going up hill the engine blogs down whenever I try to accelerate. I've put new plugs and wires on it about 2 months ago. Any help would be appreciated.
Thanks,
Wydell
Email: DaleConley1@aol.com
Old 05-17-2010, 06:37 PM
ibis1's Avatar
Talking Hard starting
BigDogg,
Both of those symptoms sound like low fuel pressure. Have you checked it? Should be around 40 psi. ibis1
Old 05-20-2010, 07:26 PM
BigDogg's Avatar
7th Gear
Originally Posted by ibis1
BigDogg,
How do I check the Fuel Pressure?
Thanks,
Wydell
WydellConley@aol.com
Old 05-21-2010, 07:19 PM
You will need to rent a fuel pressure gauge and then find the fuel pressure test port and check the fuel pressure after it has sat overnight (before starting) and then again with the engine running.
But it sounds like a bad fuel pump.
Old 05-28-2010, 04:08 PM
ibis1's Avatar
Talking Hard starting cold?
Originally Posted by chrisjohn20345
If your engine cranks slowly, your cold starting problem is not fuel related, but may be due to a weak battery, loose or corroded battery cables, or a weak starter.
Chrisjohn,
Where did he mention that it cranked slow? ibis1
ttwndoc
03-08-2013 07:50 AM
Antmen
08-13-2012 07:38 AM
texmanmoore
12-05-2010 12:45 PM
gambia
12-20-2007 01:00 PM
hmbhouse
08-23-2007 07:47 AM
Quick Reply: Hard Problem Starting When Cold???
