Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 01-22-2012, 02:18 AM
Junior Member
Default headlight
Low beam left front headlight out. high beams work on both headlights. I changed the sealed beam on the left and it didn't fix the problem. Any ideas why low beam front left would suddenly quit working and it not be a bulb problem? Thanks in advance
Old 01-22-2012, 12:27 PM
Philip Lawrence
Send a message via Skype™ to Spike555
So you changed the bulb on the left side?
Did you swap the bulbs to make 100% sure the bulb works and you didnt get a bad one?
What year and model do you have?
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-22-2012, 06:37 PM
Senior Member
Could also be a fuse, D1 uses separate ones for each side F4, F5, F10, F11. F22, F10, F9, F3 in a D2.
__________________
Old 01-25-2012, 11:57 AM
WaltNYC's Avatar
Senior Member
One possible verbiage problem.....
There are four settings for the headlamps...
1) off - stalk is turned all the way toward the driver (call it "position 0")
2) "city lights" or parking lights as they are often known. stalk is clicked on position forward. Let's call this position #1
3) Low beams. Stalk is turned two clicks forward. call this position #2
4) high beams. Stalk is turned to position #2 and then lo/hi is selected by pulling back o the stalk.
Now, based on those definitions, which lights do and don't work?
__________________
1997 Discovery I SE
89k mi.
Old 01-25-2012, 03:14 PM
Senior Member
Yep, those city lights are ultra low beams for sure.
__________________
Old 01-26-2012, 07:38 AM
Senior Member
you guys know without the year make and model it could be everything you guys haven't listed yet.
it could be a newer vehicle with alot more complicated stuff on it.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-26-2012, 10:47 AM
Junior Member
Thanks for the replies! This is a 1992 Range Rover County. The high beams work and when set to the normal low beams position #2, the right front headlight works fine but the left headlight does not. If I push the stalk forward for "hi-beams" both lights work. I replaced the left sealed headlight with one from Napa, and the same thing happened.
Old 01-27-2012, 08:48 AM
WaltNYC's Avatar
Senior Member
Rovin4life....you could be right. I thought I was in the D1 section of the forum for some reason. Brain fart
Fouts, my bad. What I wrote may not apply to you as I'm not too familiar with your vehicle. Please put your vehicle info in your 'signature' line so we can help more in the future.
__________________
1997 Discovery I SE
89k mi.
Tags
beams, county, low, range, rover, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
