Sponsored by: CARiD
Thermostat test - Soup's On!
Old Nov 29, 2011 | 08:36 PM
Default Thermostat test - Soup's On!
Heated water test of 3 stats with pix
Pix 1 - basic set up, with container selection by SHMBO.
Pix 2 - two upper stats are 195 F, note that left one has opened up faster than right one. Lower stat is a 180 F for comparison.
Pix 3 - fully open stat - note position of disc
So if you have a box full of same temp rated stats, some will be high, some low, and some on the money.
Attached Thumbnails Thermostat test - Soup's On!-p1120341.jpg   Thermostat test - Soup's On!-p1120351.jpg   Thermostat test - Soup's On!-p1120359.jpg
Old Nov 29, 2011 | 09:28 PM
wheelgarage's Avatar
Are the 195's from the same MFG?
Old Nov 29, 2011 | 09:41 PM
All three from the "MotoRad" factory.
Old Nov 29, 2011 | 11:31 PM
lordmorpheus's Avatar
Good choice on getting SWMBO's permission for container choice. Mine was rather displeased with the turkey baster used for PAS fluid exchange, and large pot to attempt to dye black clear hose for rear diff breather extension.
EATMAN
Dec 4, 2006 05:14 PM
Disco.Jay
Nov 29, 2005 06:41 PM
II2Go
Aug 21, 2005 11:49 AM
mcanavan
Dec 9, 2004 05:42 PM
