Sponsored by: CARiD
Disco died while driving and burns up fuses under dash
Old Apr 26, 2012 | 03:12 PM
RoverLady's Avatar
4th Gear
Question Disco died while driving and burns up fuses under dash
Hi, I have a 1997 Discovery. Recently replaced the fuel pump. Check engine light had come on soon after that. About a week later, was driving slowly through a parking lot and it just died and turns over but will not start. Checked the fuses, and one that has a picture of an engine was burnt up. Replaced it, and it just burnt up again. Tried to use one of those computer diagnostic things to find out what the problem was and says that it cannot link. Any help would be truly appreciated. Thanks.
Old Apr 26, 2012 | 03:50 PM
Should have had the codes read right away before toasting the system. Your only shot will be to have a good Rover tech that does electrical issues, take a shot at it and see what you fried.
Old Apr 26, 2012 | 08:10 PM
Of all the fuses to pop, you picked a good one. Satellite fuse panel 1, fuse 3, 20 amp, powers the engine computer (that's why it won't link up), four oxygen sensors, ignition coils, and the multi function relay. Here's a page from the RAVE electrical troubleshooting guide. Look for a cable from O2 being melted against something that gets hot, perhaps you'll be able to unplug O2 sensors, etc. The truck won't run at all with engine computer with no power, or ignition coils with no power, it won't run right with O2s unplugged.
File Type: pdf
Old Apr 26, 2012 | 08:54 PM
RoverLady's Avatar
4th Gear
Thanks so much - truly appreciated!!
Old Apr 26, 2012 | 08:55 PM
RoverLady's Avatar
4th Gear
Thanks so much for the quick reply. Have a great day!
Old Apr 26, 2012 | 08:56 PM
RoverLady's Avatar
4th Gear
Thanks for the speedy reply. Appreciate it.
Garover13
Oct 13, 2014 02:11 PM
bennycisco
Aug 15, 2014 11:38 AM
bennycisco
Aug 14, 2014 09:00 AM
AKFrankenstein
May 7, 2014 12:37 PM
blaze98
Oct 2, 2010 02:56 PM
