Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
manifold crack
Old Feb 14, 2006 | 02:04 AM
awsherwo's Avatar
7th Gear
Default manifold crack
if i sanded down my exhaust manifold, and aplied a jb weld, would that do the job?
Old Feb 17, 2006 | 02:54 PM
teamyonex's Avatar
Default RE: manifold crack
There was a recall on exhaust manifolds for '96-97 Discos...
Old Feb 17, 2006 | 05:24 PM
mikemeyer0's Avatar
DO NOT JB WELD IT! Any way, jb weld is a fix in an emargancy I can see, but you need to have a shop try to weld it up, they will tell you it may not hold but it will be better than JB weld. if you JB weld it, theres a good chance if it don't work you won't be able to have it welded. Also check the recall out it will prolly cover you.
Old Oct 11, 2013 | 12:17 PM
Mattvail's Avatar
Can I take advantage of that recall still? I have acrack developing
QUOTE=mikemeyer0;9103]DO NOT JB WELD IT! Any way, jb weld is a fix in an emargancy I can see, but you need to have a shop try to weld it up, they will tell you it may not hold but it will be better than JB weld. if you JB weld it, theres a good chance if it don't work you won't be able to have it welded. Also check the recall out it will prolly cover you.[/QUOTE]
Old Oct 14, 2013 | 07:31 PM
TOM R's Avatar
Call a dealer have them check your vin for recalls, I have mig welded manifolds with good results
Old Oct 15, 2013 | 08:42 AM
Mattvail's Avatar
Thanks will do
QUOTE=TOM R;425799]Call a dealer have them check
your vin for recalls, I have mig welded manifolds with good results[/QUOTE]
Old Oct 16, 2013 | 07:46 AM
Paul Grant's Avatar
If you need to buy one, I have them used for $50 plus shipping. They are glass beaded clean and thoroughly inspected for any cracks or damage. Any studs are cleaned and all the threads are chased. Let me know if I can be of any help.
Old Oct 17, 2013 | 08:53 AM
Mattvail's Avatar
Please pm me your info and I will follow up
QUOTE=Paul Grant;426061]If you need to buy one, I have them used for $50 plus shipping. They are glass beaded clean and thoroughly inspected for any cracks or damage. Any studs are cleaned and all the threads are chased. Let me know if I can be of any help.[/QUOTE]
Racer X
Jun 13, 2015 10:40 PM
jkeving
Mar 8, 2007 03:28 PM
angasreid
Feb 11, 2007 09:05 PM
monk
Sep 21, 2006 07:02 PM
DiscOwner
Mar 25, 2005 03:55 PM
