Window Clunk/Crack Noise in 2004 D2
Old Feb 11, 2007 | 07:07 PM
angasreid's Avatar
Default Window Clunk/Crack Noise in 2004 D2
I was rolling my windows up today when both sides made a huge clunk noise while almost rolled all the way up. Then they both wouldn't roll back down until I rolled them back up a bit. Any ideas?
Old Feb 11, 2007 | 09:05 PM
Darover's Avatar
Default RE: Window Clunk/Crack Noise in 2004 D2
Same thing happened to me on the passenger's side, to the point that the window almost got out ofit's track. It ended up being the first big torx bolt on the end of the door that somehow was then hitting the window track as it went up or down. All I did was pull out that bolt, and install a little washer to ensure that it wouldn't go as far in the door. Problem solved!!!
Why did it suddenly start happening???? Your guess is as good as mine. But what I did worked, and I hope it'll solve your problem too.
Cessna310Guy
Nov 14, 2008 08:06 PM
DiscoMike2003
Nov 13, 2008 04:57 PM
tsuami1
Jun 20, 2008 07:53 PM
MyRover01
Jun 18, 2008 11:22 AM
msbont
Sep 10, 2006 03:53 PM
