Service issues...
Old Nov 15, 2008 | 02:34 PM
m1964's Avatar
Default Service issues...
Brought the carfor 18 mo. service -left 2 cases of synthetic oil IN FRONT of the passenger seat, and asked advisor to use that oil-after the service found oil still there, and they used regular 10-30 oil.
Question: owner's manual says to use 5W-30, and the dealer used 10W-30, is it a problem or not?
I am asking because of the cold temp. coming-heavier oil may be too heavy in the winter..?
Old Nov 17, 2008 | 09:52 PM
tacomatech's Avatar
Default RE: Service issues...
We use 10w-30 at our shop as well. We haven't seen any problems, your vehicle should be fine. I would have pitched a fit though. When it comes down to it, it is your vehicle and if you request they use your supplied oil, then that is what they need to do. If a customer comes to us with their own oil, we make sure that is what we use.
Old Nov 17, 2008 | 10:40 PM
m1964's Avatar
I guess I am due to a trip to my old trusted mech in 3 mo for another oil change before next "factory scheduled maintenance" .
Old Nov 18, 2008 | 09:38 AM
Not having read your owners manual, there are usually different weight oilds that are recommended depending on the cold temp during the winter and how hot you get in the summer.
All that being said, the only thing you want to stay away from is one of the 5oW oils if you are in snow country.
I run a 5W/30 in the winter here in Denver and a 10W/40 the rest of the time.
Old Nov 18, 2008 | 07:27 PM
djones2084's Avatar
5th Gear
Default RE: fuel additive in 2003 range rover
i have a 2003 range rover with 81000 mikes and its running totally fine.i was thinking since its getting reall y cold to add some seafoam or valvoline fuel and engine cleaner.Do you reccommend adding any additive to my fuel system and what your opinion on the product seafoam?please advise thanks.
Old Nov 19, 2008 | 06:42 PM
m1964's Avatar
ORIGINAL: Disco Mike
The manual says 5W-30, so I was not happy when they put 10w-30 for the winter. I would not mind 10W30 if theydid itin May...
So, in Feb I just do another oil change with 5W-30.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
msturdy
Jul 13, 2007 11:04 AM
mr2xxx
Dec 26, 2004 11:43 PM
JA-NH
Jul 31, 2004 02:13 AM
