1 day after 60k service, "service engine light" turned on
Old Jul 4, 2009 | 06:08 PM
kcferna's Avatar
Default 1 day after 60k service, "service engine light" turned on
I have a 2004 DII, S with 40K miles that just had the 60k done by a local shop (non-LR dealer). DENSO platty plugs were used since the original Champion plugs don't exist in addition to all services listed in the owner's manual (transmission / brake flush, etc.). Also had new pads and rotors installed using original LR factory parts.
After about 20 miles of driving, the service engine light turned on. I plan on bringing back to the shop shortly and know that there are a million reasons this light can turn on, but anyone have any theories?
Old Jul 4, 2009 | 06:27 PM
Nope, not until we have the codes.
Old Jul 4, 2009 | 06:36 PM
Find a local parts store, some will still read the codes for free, get us the 4 digit numbers and a break down on what exactly he did.
Old Jul 5, 2009 | 12:22 PM
kcferna's Avatar
Went to Advance Auto Parts and they check the codes. Here's what showed up: P0442 "Evap emissions control systems leak (small)".
The store thinks this could be from the gas cap being loose or adjustments made during the 60k service a couple days ago. He thinks it will go away in a couple days on its own.
I've had this problem with the gas cap seal before and once the dealer had to have the thing replaced under warranty, so this code reading makes sense. What you guys think and why does this keep happening?
Old Jul 5, 2009 | 12:42 PM
Well if your gas cap is tight then it is prob a evap leak in the fuel return line/purge valve.
Old Jul 5, 2009 | 01:05 PM
No body has verified it is the cap yet, get it checked cause there are a number of evap related parts and hoses that cause this to happen, and the cap is not the usual cause, just always gets blamed for it.
Old Jul 5, 2009 | 07:38 PM
kcferna's Avatar
Ok, thanks. I will get the engine light checked ASAP. If it's not the gas cap, but rather another evap related part, is this serious?
Is it possible that in the process of the 60k service the mechanic did something to trigger this light. If yes, this is another reason for me to just pay the extra cash and go to the dealer for service and avoid all this damage control...
Old Jul 5, 2009 | 08:12 PM
No the 60k did not trigger this unless the mechanic dumped some injector cleaner into your gas tank and he did not replace the gas cap tight enough.
Just take it back to him and play dumb, "hey you worked on my truck Fri. and now the check engine light is on, can you help me?"
Old Jul 7, 2009 | 08:33 AM
kcferna's Avatar
That's what I did Spike and they found the same evap code that Advance Auto Parts did. They "smoked" the system to find any leaks and didn't find any. They attributed the light to a possible loose gas cap. They reset the light and everything seems to be in order.
zeblitz
Aug 24, 2014 08:33 AM
sdeleve
Feb 21, 2012 10:43 AM
WaltNYC
Jun 9, 2011 10:08 AM
meltdowndave
Apr 21, 2008 07:39 PM
40ranger
Mar 19, 2008 05:11 PM
