License Plate light replacement
There are two clear lights, one either side of the tailgate electronic popper.
Open the tailgate at an angle so that you can see them clearly. You will notice on one side of the lens there is a notch where you can put a screwdriver. gently insert a screw driver and pop it off, you can remove the lamp this way.
that video is good. I have done that procedure to change the color of the tailgate handle. just be careful removing the entire handle once removing the nuts & the electronic supply. As the plastic fasteners on the inside of the handle become weak over time and might snap off. (happened to me on one)
bcolins
07-09-2011 08:58 AM
bcolins
06-05-2011 09:21 PM
Tom Sederburg
11-16-2009 04:34 AM
