remote battery and programming
Old Mar 15, 2010 | 11:16 AM
compfranon's Avatar
Default remote battery and programming
My remote started playing up a while back, I suspected the battery may have been discharged. I took the remote apart with difficulty, and the battery is soldered on to the board.
With a bit of effort the battery is no removed, and I am soucrcing a replacement.
When I replace the battery will I have to reprogram the remote, if so is there a way to do it without having to pay the dealer £90. I still have a working second key.
Appreciate any help.
Old Mar 16, 2010 | 06:42 AM
Rovin4life's Avatar
freelander or freelander 2?
Old Jun 19, 2010 | 05:01 PM
compfranon's Avatar
Freelander 2 HSE 5 Button remote
Just ordered a replacement battery with the solder tags attached.
Old Mar 29, 2011 | 02:44 PM
compfranon's Avatar
Now my other remote has stopped working, this is a real PIA.
Is there an easy way to open this remote up to replace the battery, my last attempt almost ruined it.
Any alternative sources for a replacement casing.
Old Apr 1, 2011 | 07:55 PM
compfranon's Avatar
I had to break into my remote and replace the battery, it's working fine now.
I'm just concerned why it doesn't appear to be charging properly, it's used every day, and according to the manual it's charged when docked and the engine is running
Surely this shouldn't be happening, or at least the remote should be relatively easy to open and an "unsoldered" battery available for replacement.
Hope someone can help.
jigray3
Nov 17, 2007 09:26 PM
whigham42
Sep 29, 2007 08:09 PM
onid888
Nov 28, 2006 09:21 AM
rangeroverboi
Jun 10, 2006 02:33 PM
oberdahill
Nov 26, 2005 01:53 AM
