When pavement covered by snow LR2 sounds on reverse
Old Jan 30, 2008 | 02:00 PM
mht2007's Avatar
Default When pavement covered by snow LR2 sounds on reverse
Wondering, if it is an issue or feature: when there isa thin layer of snow on the pavement and you reverse, the sound is as if you hitting someone by the car's back. It may be really thin snow layer.
The feature works in the following way: you reverse and when come closer to the object, car starts to beep and the frequency of beeps is increasing with becoming the sound, never stops, when you hits.
That is the sound, i am hearing now on the snowy roads every time, when i reverse.
Any ideas?
Old Feb 1, 2008 | 01:11 PM
mikello's Avatar
Default RE: When pavement covered by snow LR2 sounds on reverse
I have driven on snow a lot but I saw this only once when the sensors were completely covered with snow and ice. In that case it is expected to hear that permanent sound.
Mikhail
Old Feb 3, 2008 | 04:40 PM
saqqara lights's Avatar
Yes, same here. Clear off the sensors and the problem disappears.
Old Feb 5, 2008 | 10:14 AM
mht2007's Avatar
correct! It helps, when it is not snowing
dieselmissfire
Feb 6, 2015 06:39 AM
jwigum
May 27, 2014 06:43 PM
bballjames
Dec 14, 2012 10:58 AM
amkullar
Dec 23, 2008 06:01 AM
DiscoII
Mar 19, 2008 09:09 AM
