Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR2
Register Forgot Password?
Old 03-15-2010, 11:16 AM
Junior Member
Default remote battery and programming
My remote started playing up a while back, I suspected the battery may have been discharged. I took the remote apart with difficulty, and the battery is soldered on to the board.
With a bit of effort the battery is no removed, and I am soucrcing a replacement.
When I replace the battery will I have to reprogram the remote, if so is there a way to do it without having to pay the dealer £90. I still have a working second key.
Appreciate any help.
Old 03-16-2010, 06:42 AM
Senior Member
freelander or freelander 2?
Old 06-19-2010, 05:01 PM
Junior Member
Quote:
Freelander 2 HSE 5 Button remote
Just ordered a replacement battery with the solder tags attached.
Old 03-29-2011, 02:44 PM
Junior Member
Now my other remote has stopped working, this is a real PIA.
Is there an easy way to open this remote up to replace the battery, my last attempt almost ruined it.
Any alternative sources for a replacement casing.
Old 04-01-2011, 07:55 PM
Junior Member
I had to break into my remote and replace the battery, it's working fine now.
I'm just concerned why it doesn't appear to be charging properly, it's used every day, and according to the manual it's charged when docked and the engine is running
Surely this shouldn't be happening, or at least the remote should be relatively easy to open and an "unsoldered" battery available for replacement.
Hope someone can help.
Tags
08, apart, batteries, battery, change, freelander, key, land, lr2, lr3, remote, replace, replacement, reprogramming, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
