Shifter D illuminated, lit.
Old Apr 7, 2015 | 01:05 PM
Ghaniba's Avatar
Default Shifter D illuminated, lit..
Folks,
I've got my 2005 LR3, which is still very new to me. I've been looking over it for problems and issues or any oddities I can find, and I have come up with a couple things I'd like some thoughts on, as they may be related.
Shifter gives me zero problems switching between park and drive, shows it on the dash properly. When I kick it to the left for "sport" mode - it stays in D, according to the dash. up or downshifting makes no change, does nothing. Someone stated this may be some corrosion under the truck on the side of the transmission, for the linkage. It sure seems to clunk over properly, but I plan on checking that out to be sure.
The other oddity I've found related to the shifter that I've not had a great time searching for -- D is illuminated on the shifter. All of the time. When I'm out of the truck and the truck is off, the D is lit. I'm assuming this is NOT normal?
I've scanned the truck for codes and none come up for the transmission. Plenty for HVAC vents, etc but nothing for transmission.
Thoughts on this?
Dave
Old May 12, 2015 | 02:38 PM
Hawk99's Avatar
Hey Dave,
Just to keep this thread alive, I have a similar small issue.
My 2005 has the R illuminated all the time whether in Park or Drive. The shifting works just fine, including the sport shifting.
Hopefully someone has figured this out.
Andrew
Old May 12, 2015 | 06:57 PM
unseenone's Avatar
Probably need new shift linkage.. particularly if you are in a rust belt. I have all the parts, but have not had the problem yet.
This is not guaranteed, but a good start point.
Shift Components
LR012704 - Lever
WYH000040 - Nut - flanged
VYH500020 - Nut - Hex
TYG000050 - Bolt
TZT500040 - Bush
TYF000050 - Washer - spring
Old May 13, 2015 | 11:24 AM
Hawk99's Avatar
I believe the mechanical linkage sends gear selection status to the dash indicator, not the indicator by the gear lever. So I don't think this could be the issue.
I guess what I am looking for is what makes the gear indicator by the lever light up. Electrical contacts in the lever assembly? Anyone know?
Old May 14, 2015 | 05:30 AM
Ghaniba's Avatar
This is my assumption as well, which is why I haven't bothered taking it apart just yet. It's on the list, just not high up on it.
Dave
Old May 4, 2024 | 02:05 PM
ErnestLR3's Avatar
Originally Posted by Ghaniba
Folks,
Thoughts on this?
Dave
I have a video I made. Remove the shift selector and look at the green circuit card that the harness connects to. I’m sure there is pins corroded at the bottom. I know this may be a little late, but I’m sure other have the same issue. This causes a transmission fault and keeps the gears illuminated even when you turn the truck off. Mine was stuck in “D” at all times even when shifted into park. Hopefully this could help someone.
here is the link
https://youtu.be/QIq-S07_GCM?feature=shared
Old May 4, 2024 | 07:00 PM
loanrangie's Avatar
That post is 9 years old, he's either fixed it or moved the vehicle on by now.
Old May 4, 2024 | 07:19 PM
ErnestLR3's Avatar
oh I’m sure. I just know I didn’t see an answer for it. Someone else with an LR3 will probably be looking for an answer as well.
Old May 4, 2024 | 07:24 PM
loanrangie's Avatar
I did about 2 years ago.
Old May 4, 2024 | 10:06 PM
DakotaTravler's Avatar
As long as info is added that helps, I think thread necromancy is fine.
rolo405
Nov 20, 2022 08:59 AM
loanrangie
Feb 13, 2021 05:11 PM
driscoii
Apr 24, 2012 07:47 AM
dennyb
Oct 8, 2009 09:37 AM
