4 wheel drive
Old Oct 7, 2009 | 09:15 PM
dennyb's Avatar
Default 4 wheel drive
1996 discovery,im have trouble shifting in gear or out of gear ,i think it's in high. i can't get the shifter to move.
Old Oct 7, 2009 | 09:17 PM
NiteTrain's Avatar
if you can go over 30mph then it's in high. try greasing the shift linkage underneath the rover and work the shifter to loosen it up.
Old Oct 7, 2009 | 09:32 PM
lipadj46's Avatar
It can be very stiff if you don't shift it into low often. Spraying a little PB blaster or WD 40 at the shifter linkage and trying to shift it a few times with force can help break it free then put some sort of lubrication on it. If you are pushing with all your might there is a solenoid that goes bad that can prevent you from shifting and it would need to be replaced.
Old Oct 7, 2009 | 09:50 PM
tweakrover's Avatar
or removed
Old Oct 7, 2009 | 10:35 PM
oysterhead's Avatar
make sure when shifting you are either:
1. rolling in neutral
2. sitting still in neutral but pushing on the gas
Old Oct 8, 2009 | 09:37 AM
To clear up this statement, never push with all your might, you will bend or brake the linkage.
You either need to get the linkage assembly cleaned and lubed or remove/replace the shift solenoid.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
BENROVERN
Nov 5, 2007 09:19 AM
Randy P
Sep 27, 2007 08:27 AM
bryanjess
Nov 10, 2005 01:03 AM
