Cannot manually shift into 1st gear
Old Apr 23, 2012 | 09:23 PM
driscoii's Avatar
Default Cannot manually shift into 1st gear
I need some advice/help with my D2 problem. I have an 03' Disco with 145k. Everything operates and drives smoothly. I have done a ton of maintenance, etc on it since I bought it. The only problem I am still having, is that I cannot manually shift the transmission into 1st gear. It doesnt matter if I am in low or hi, stopped or moving. In drive it seems to work just fine.It just physically will not go into 1st. Any ideas, suggestions? I really appreciate any guidance!
Old Apr 24, 2012 | 07:47 AM
drowssap's Avatar
the first thing "I" would do is pull the cover off the shifter and see if anything has fallen into the shifter keeping from moving all the way back to first. The second thing to check would be the adjustment on the XYZ switch, but you will need someone inside the truck moving the shifter in order to check it.
importdave
Sep 25, 2014 10:18 PM
Illya
Jul 28, 2013 04:25 PM
jfall
May 16, 2012 08:08 PM
dominiquetx
Mar 9, 2012 11:53 PM
Skimino Farms
Jul 30, 2011 07:47 AM
