High Beam issue
Old Apr 1, 2012 | 09:44 AM
sbutler's Avatar
4th Gear
Default High Beam issue
I have a 2007 LR 3.
Maybe im searching the wrong terminology for this issue and that is why I couldn't fimd an answer in the forum.
Everytime I use my turn signal, left or right, my high beam lights turn on. Oddly enough its usually in the evening or dusk hours. Anyone else having this problem or know what's causing this?
Thanks!
Old Apr 1, 2012 | 09:46 AM
sbutler's Avatar
4th Gear
Forgot to mention that when i want to use the high beams, i have to hold the lever for them to stay on or just turn on my signal...
Old Apr 1, 2012 | 10:32 AM
unseenone's Avatar
Well it sounds like the switch in the steering column is bad. You should be able to replace it, or have it done. Here is a link to the signal switch.
2007 LAND ROVER LR3 Parts - Land Rover Parts Center - Call (800) 574-9217 for Genuine Land Rover Parts and Accessories
Old Apr 2, 2012 | 04:49 AM
sbutler's Avatar
4th Gear
Thank-you
AK Rover
Apr 1, 2009 12:15 AM
Gomie
Feb 3, 2009 03:16 PM
Disco_Dare89
Aug 8, 2008 05:13 PM
LR4LIFE
Nov 6, 2007 10:23 PM
northgadisco
Apr 28, 2007 06:24 PM
