High-beam turns off when using Left Turn signal
Old Feb 1, 2009 | 11:09 PM
Gomie's Avatar
3rd Gear
Default High-beam turns off when using Left Turn signal
I'm not sure if this was always the case or if this is some thing that just started happening. I have a 2005 LR3 and unlike the manual states I have to pull the left stalk back to get the high beam to come on, the stalk does not push forward in any light switch mode. I just noticed when driving with my High-beam on (by pulling the stalk towards myself) when I use the left turn signal the high beam turns off, if i use the right turn signal the high-beam continues to stay on. Is this normal or has anyone else had this problem?
Thanks guys!
Ryan
Old Feb 2, 2009 | 05:55 AM
Jantiz's Avatar
Default RE: High-beam turns off when using Left Turn signal
Not normal at all. It should move forward and stay to give you high beams. Sounds like a bad "stalk". Pulling back to get high beams is only temporary and should reset if you let go.
Old Feb 3, 2009 | 03:16 PM
Gomie's Avatar
3rd Gear
the "Stalk" was the issue, the dealer ordered a replacement, said it was going to be about $150 for parts and labor, sounded like a a good price to me actually. Thanks again Jantiz!
Lord Wert
Jul 4, 2013 07:52 AM
Thatdudeuno1
Mar 11, 2012 11:13 AM
haverhillguy
Feb 11, 2010 08:24 AM
LR4LIFE
Nov 6, 2007 10:23 PM
LordOphidian
May 30, 2006 03:00 PM
