LR3 Leakage Problem
Old Mar 22, 2011 | 05:49 PM
sbezhanski's Avatar
4th Gear
Default LR3 Leakage Problem
Hello all,
I have the following problem. When it's raining outside a water start to leak from the 2 front frame airbags (see the picture attachment) as well as the small hole, which is next to the inside lights next to the inside rear mirror.( second attachment). Does anybody have an idea what could be the problem? I think it's somewhere around the sunroof, but I can't figure out.
Thanks!
Attached Thumbnails LR3 Leakage Problem-front-air-bag.jpg   LR3 Leakage Problem-front-leakage.jpg
Old Mar 22, 2011 | 06:45 PM
Mack73's Avatar
sunroof drains are clogged: DISCO3.CO.UK - View topic - How to fix a Sunroof Leak!
Old Mar 24, 2011 | 09:09 PM
n1keaddict's Avatar
Can you pinpoint or 'arrow out' where its leaking? I kept looking for it on the pictures you posted like an old blind man an inch away from the screen...
Old Mar 25, 2011 | 01:51 PM
sbezhanski's Avatar
4th Gear
@Mack73 Thank you! I will see that I can do this weekend. Hopefully I don't break anything.
@n1keaddict The new images are attached.
Old Mar 25, 2011 | 03:11 PM
sbezhanski's Avatar
4th Gear
I found the sunroof troubleshot manual
http://www.disco3.co.uk/gallery/albu...%20Ingress.pdf
Anyway Thanks for your help!
Old Apr 3, 2011 | 05:51 PM
js80's Avatar
I had the exact same problem with my 2005 LR3 this spring (including where the water was coming out). The problem was that all 4 sun roof drains were clogged.
Apparently, they drain into the wheel wells somewhere (not quite sure where) so over time, they can get clogged up even though they are protected somehow. The shop I took it to charged ~$325 to clear the drains -- it just takes time to disassemble all of the wheel wells, they said.
Old Apr 4, 2011 | 12:50 PM
sbezhanski's Avatar
4th Gear
I cleaned the passenger's roof drain (the front and the back) and it took me like 10 mins to clean them. However the driver's one are pretty complex to do. I didn't have the exact screws and the time to do it. I don't have the Body manual to do it either - that means additional time to figure out how to do it. May be there is a reason they charge you $325.
beachpugx1
Feb 23, 2012 09:40 PM
jdelp
Aug 16, 2007 03:00 PM
johnnybob06
Jul 18, 2007 12:16 PM
mummra
May 29, 2007 09:48 PM
JEFF
Apr 29, 2007 11:15 AM
