Transmission fault
Old Aug 10, 2011 | 08:32 PM
lsubayoubengalz's Avatar
5th Gear
Default Transmission fault
My LR3 doesn't want to start from time to time and tonight a large F appeared on my dash beside my mileage and none of the off road modes were working. Can anyone tell me what is going on?
Old Aug 11, 2011 | 01:01 AM
socalrovershop's Avatar
many things can be wrong at this point, does it crank over or it doesnt even do that? let me list you the quick things you can look at. possible fluid spill by the shifter and corrodes the shifter connector. possible battery leak/explosion caused tbox module to short or water damage. those are the most commen areas i have ran into
Old Aug 11, 2011 | 04:34 AM
It is obviously an indicator that college football will soon grip the nation - Geaux Tigers - need to get that radio and flat screen TV set up in the garage....
Old Aug 11, 2011 | 09:34 AM
5th Gear
The alarm has been going off just about everytime you lock the doors and walk away. Also lights sometimes blink numerous times when I lock the doors. I am thinking maybe it just needs a new battery. Maybe losing connection or something. The car fired up this morning with no problems, but all these things seem to be happening quite often. Don't really have a clue.
And yes Geaux TIGERS!!!!'
Old Aug 11, 2011 | 03:38 PM
A new battery chases away a lot of gremlins. Cheaper than have the dealership valet park the truck before the tech specialist even glances at it....
Old Aug 11, 2011 | 10:32 PM
sounds to me like a short somewhere possible water damage on passengers kick panel and or shifter area seen it many times
Old Aug 16, 2011 | 08:39 PM
5th Gear
So I go to the local auto parts store to purchase a battery and they tell me that the computer may need to be reset after changing it. Is this true or not?
Old Aug 16, 2011 | 10:32 PM
no, only true on 2010 and new vehicles.
06Range
May 8, 2013 09:01 PM
mrb06lr3hse
Aug 18, 2012 10:26 AM
anhernandez
Aug 18, 2009 12:47 AM
