changing engines
Old Mar 19, 2018 | 10:18 PM
brocklr4's Avatar
Default changing engines
can i take a lr4 v8 engine and put in LR3 that has a 4xylinder diesel engine? Are the beds and bolting up different?
Old Mar 20, 2018 | 06:55 AM
loanrangie's Avatar
For a start they never came with any 4cyl motor, and as far as conversions go you would need to swap out every ECU in the car to make it work so just by a V8 vehicle.
Old Mar 20, 2018 | 07:22 AM
brocklr4's Avatar
So.the thing is I have the lr3 that' a diesel engine. Im just wanting to.keep the body and use a lr4 as a donor vehicle. The worry is if I can transfer everything without an issue or will the lr4 engine not fit in the lr3
Old Mar 21, 2018 | 09:29 AM
djkronik57's Avatar
You would probably have to transfer everything over...like almost all of it aside from the frame/chassis. Not worth it.
Old Mar 21, 2018 | 08:06 PM
spannermonkey's Avatar
Agreed with the others, its a huge amount of work and effort when you could just sell the LR3 and the LR4 engine that's going to be worth a pretty penny on its own and just buy a V8 LR3. I'm assuming if you have an oil burner you are in Europe or possibly somewhere down under.
aussiejo
Defender
Nov 27, 2006 10:27 PM
karl_page
Dec 27, 2005 05:45 PM
01greendisco
Oct 12, 2005 01:14 AM
nikos
Jun 12, 2005 02:05 AM
nikos
Jun 2, 2005 02:20 AM
