Source Tone Memory & Aux Volume
Old 01-18-2007, 09:49 PM
MINIrover's Avatar
4th Gear
Default Source Tone Memory & Aux Volume
Does anybody know what function does the "Source Tone Memory" do on the audio system? The manual does not provide any explaination. From what I thought,the function lets you set the bass, treble, etc independently for each audio mode (Radio, CD, & Aux). However, this doesn't seem to be the case. Secondly, when I tried to set it to ON, it would go back to OFF when I go back to check its status.
[:@]Is there a way to control the auxiliary volume? To get good volume when using my iPod (with the volume set at 4/5 to the max level), myaudio volume needs to be at 20+. This creates a problem as the volume gets so loud when I use the NAV (set at +1, being the lowest). So my question is,is therea way to increase theauxiliary volume? This way, I can lower the audio volume and at the same time my NAV volume won't be too loud to damage myear drums. I really wonder if I'm the only one experiencing this problem.
Old 02-02-2007, 12:29 AM
Mitchss's Avatar
Default RE: Source Tone Memory & Aux Volume
Not sure about the Source Tone Memory. Just picked up my new 06 LR3 HSE today! I do know that the problem you have with your Ipod and low volume is not the Rover's fault. I have the same issue with my Ipod and Saab as well as Ipod/home stereo. After some internet searching a while back, it appears this is an Ipod problem or setting which can not be easily changed. It is due in part to the output from the Ipod being at earplug levels or something. I don't remember all of the specifics. Might try a search on google for low ipod volume or something.
Old 02-23-2007, 08:39 PM
Tink's Avatar
you can adjust the volume of the navigation independently of the rest of the volume. you can find the settings in the nav settings. For some reason my nav lady sounds like a 80 year old life smoker. She is on mute.
Old 07-20-2011, 10:46 AM
alpinepursuits's Avatar
This feature allows you to store bass, middle and treble tone settings for each source (MD, FM, AM, Changer, Aux)
MINIrover
Audio/Visual Electronics
07-20-2011 10:49 AM
mavrck333
LR2
05-08-2009 09:17 PM
nola000
12-22-2008 08:44 PM
nola000
12-22-2008 07:22 PM
dw00594
09-11-2008 06:02 PM
Quick Reply: Source Tone Memory & Aux Volume
