Dual Batteries Research!!!!!
Old Oct 27, 2008 | 04:51 PM
roverwoody's Avatar
Default Dual Batteries Research!!!!!
Im trying to researcha dual batteries system in my Disco. Any ideas?
Old Oct 27, 2008 | 05:35 PM
Default RE: Dual Batteries Research!!!!!
On a D1, you can add a second battery over by the air filter with just a little work, then tie the batteries together or throw a switch between them.
Why are you looking for duals and what battery are you looking at?
Old Oct 31, 2008 | 11:39 AM
roverwoody's Avatar
I have an after market audio system with 2 powerful amps. I audio shop recomended to add a second battery. I trying the do it the less $$$$ way but, still get it done so it work like it should. Later I want to add lights and a winch!
Old Oct 31, 2008 | 01:01 PM
If you will also be going for a winch, go to Deep Cycle batteries now, like Yellow Tops.
Old Nov 7, 2008 | 08:08 AM
nuyorican420's Avatar
7th Gear
Yellow top's are trash. Try a DieHard Marine Battery, Platinum PM-1 - Group Size 31M from sears. Do it right the first time.
Old Nov 7, 2008 | 09:44 AM
Well that trash works well for many of us. Have you ever tried one or are you into hear say?
Old Nov 7, 2008 | 02:03 PM
discoxd's Avatar
the best thing to do to keep your audio system from draining your batteries and putting a strain on your alternator is to have a capacitor installed... i had a 1.5 farad capacitor and a 2000 what amp with two tens in my old car and when i turned it up and the bass hit the capacitor kept my lights from dimming like they would have without it...
________
EmiliaHot
Old Nov 10, 2008 | 06:15 AM
7th Gear
So, Your saying that Yellow tops are better than oddessy's? Cause, that's whatthat searsbattery is. Just stating the facts...
Old Nov 10, 2008 | 07:27 AM
The facts are there are a couple of different Odessey batteries, and the company that makes them also makes a battery for Sears, but I believe that the Sears version is of lesser quality the the original Odessey.
As for the comparison between the Yellow Top and the Sears battery, all I can say is mine duals work well and were way more cost effective then 2 Odessey's.
Old Nov 18, 2008 | 05:36 PM
apcollin's Avatar
does adding a second battery put a great deal of strain on the alternator?
if you were to put one in place, would you just connect it to the existing battery: pos to positve, neg to neg. ?
