lift kit-2 choices
Old Dec 3, 2008 | 11:42 PM
phidelt583's Avatar
Default lift kit-2 choices
OK guys so I have narrowed it down and I have to make a choice between two lifts. But I can't make up my mind which would be better. And I know I will need alot more to finish the project....this is just the starting point lift.
Option A:
Rovertym 3" lift kit[*]3" Lift with Bilstein 7100 Series Shocks (For RRC, D90, D1 and DII)[*]Bilstein 7100 series shocks $720.00[*]RTE 3" springs $315.00[*]Front shock towers $96.00 (not required on DII)[*]Front lower shock mounts $35.00[*]Rear shock mounts $155.00 (not required on DII)[*]Rear spring retainers $45.00[*]Brake lines $26.00 each (4 or 6 lines required)[*][*]ABS Extensions $75[*]Crossmember Spacers $30[*]Bilstein Reducer Bushings $40Kit Price for DII - $1286.00
Option B:[*]Rovertym 2"springs $315.00[*]OME shocks $349.00 or Bilstein $379.00Brake lines $26.00 each (4 or 6 lines required)
And a 1.25" body lift
cost: about $950
Old Dec 4, 2008 | 07:33 AM
hazletbassist89's Avatar
Default RE: lift kit-2 choices
Personally I'd go with option A, but with either one you go with, consider changing out your driveshafts for longer ones. 3" lift is right where they start to get to the upper limit and develop problems. I've heard of people being fine on the stock ones with that lift, and I've heard of people saying it was a no go within a few weeks. Just something to consider
Old Dec 4, 2008 | 08:54 AM
phidelt583's Avatar
yeah they are in the plans....but I will have to do some daily driving with the stock ones....no off-roading though.
Thanks for the input Hazletbassist89
Old Dec 4, 2008 | 09:05 AM
Where do you live, how much off roading and what degree of difficukty are these trails?
Old Dec 4, 2008 | 09:23 AM
phidelt583's Avatar
Well I live in florida where it is mainly mudding with some ruts. However i am moving to Colorado for a few years and I hope to try out some rock crawling. Not too much since I have never tried it, but i at least want to give it a try. I will then be moving back to Fl so I kinda need both a mud and rock setup
Old Dec 4, 2008 | 01:23 PM
I am ruuning an OME lift along with my SLS which measure an easy 2.5"s and that works well on the trails I have run in Colorado.
If it were going to be a weekend vehicle for crawling, I wouls look at the 3" but since it isn't I would not get too crazy with the lift, remember you will still be looking at traction issues to get you thru the mud and over our rocks.
Old Dec 7, 2008 | 06:48 PM
phidelt583's Avatar
OK I was also wondering, if I go with the 2" lift alone would any additional parts be needed? And if I did the body lift on top of it, would any parts then be needed? I am sure brake lines would be needed but what about the abs extention?
Old Dec 7, 2008 | 06:53 PM
No ABS extensions are needed or other parts with a 2" plus lift.
Old Dec 7, 2008 | 08:54 PM
phidelt583's Avatar
OK thanks again
Old Dec 8, 2008 | 12:36 AM
llesra's Avatar
option a! youll never have to buy shocks again since the 7100s are rebuildable.
Bostonc16
Mar 7, 2015 10:32 AM
tasr12
Dec 17, 2009 01:17 PM
Galaxie_406
Jan 5, 2009 07:03 PM
stefan
Jul 8, 2005 08:46 PM
