Fitting a Crank handle???
Old Oct 4, 2011 | 03:21 AM
ChuckNorris's Avatar
Default Fitting a Crank handle???
This may seem a bit odd, so be prepared!
Id like to know if anyone has or has at least considered fitting an old fashioned manual cranking handle to their Landy? (The old type that was replaced by the starter motor? The handle that was cranked over a few times to start vehicles.)
Anyone know if this is possible?
Thanks
Old Oct 4, 2011 | 04:16 AM
To practice, take your socket wrench and attach to large nut on the lower pulley (crank shaft pulley). Turn 360 degrees 10 times. Do this with the key off the first time.
IMHO batteries are a great invention.
Old Oct 4, 2011 | 08:18 AM
No, it can't be done and why would you want to, you can't even get a straight shot at it without removing the radiator.
Old Oct 4, 2011 | 08:44 PM
You cant do it with a V8 or a TDI, it must be a 4 or 6 cylinder petrol.
LAND ROVER PARTS - HAND CRANK - 4 & 6 CYL SERIES II, IIA AND III
Series Land Rover Hand Crank - YouTube
Old Oct 5, 2011 | 02:57 PM
Thanks for all the info/advice! I certainly have something to think about!
Old May 7, 2012 | 08:30 AM
spicer's Avatar
4wd High
They say they put a man on the moon
with enough engineering I don't see why you couldn't
one with a spring you could wind up and release from in the cab would be cool
off set it so it goes beside the radiator and spins the belt or some such thing
Old May 7, 2012 | 08:40 AM
If it would be cheaper they would. Try spinning the engine with your breaker bar and socket on the crankshaft bolt. Get that V-8 to about 80 rpm like the starter does. Then decide on just how large a spring you will need on a winter day....
But yes, engines in some things are started by compressed air, cranks, electric or air powered wrench (some racers), ropes (boat motors under certain HP), even blank shot gun shells (old fighter planes and crop dusters).
But since you already want a robust electrical system to illuminate the six Hella lights on the roof rack, and power the 1200 watt stereo; the electric starter is there.
and re: They say they put a man on the moon - yep, we did.
Old Jun 9, 2012 | 07:25 AM
drowssap's Avatar
yah, thats it just put a big pull cord on it like your lawn mower, yah thats the ticket
bulbaelmus
Feb 23, 2023 05:31 PM
D2 2003
May 22, 2007 12:32 AM
solihulldiscotruck
Apr 1, 2007 04:11 PM
nford
Appearance & Camping Set Ups
Oct 7, 2006 09:20 AM
william
Sep 24, 2006 02:41 PM
