Lift kit advice
Old Nov 3, 2008 | 08:47 PM
jsf's Avatar
jsf
6th Gear
Default Lift kit advice
I am looking for advice on lift kits for a 2003 discovery and tire size recomendations.
Old Nov 4, 2008 | 10:09 AM
Default RE: Lift kit advice
What sort of wheeling are you planning on?
There are some good kits out there depending on your needs and other modifications/weight.
Old Nov 4, 2008 | 12:25 PM
llesra's Avatar
3" rovertym lift with 285/75/16s
Old Nov 5, 2008 | 02:29 PM
jsf's Avatar
jsf
6th Gear
I enjoy trails with a moderate degree of dificulty. I need to start out slow to get back into it. i havent even driven on any trails in a couple of years.
I do not want to have to modify a lot of components at first, i realize i may have to do that in the future, but i want to keep it simple at first. I have seen some 2" lift springs from ome and i think rovertym, does anyone know what other parts need to be modified when those springs are installed (brake lines, shocks, driveline, bump stops, etc) also what size tire can i run without having to do any trimming?
thanks
Old Nov 6, 2008 | 09:09 AM
Will you be adding a winch or bumper in the future, this will determine what 2" lift you should consider.
Other then coils, shocks and a steering stabilizer, the only thing you may want to consider changing would be the brake lines. The rubber lines do age and cause problems, the replacement stainless steel lines are a little long and don't wear out like the rubber hoses.
Old Nov 6, 2008 | 09:51 AM
jsf's Avatar
jsf
6th Gear
I do plan to add a winch and some form of winch mount or bumper.I like the arb bumpers, that is most likely the route that I will take.
Old Nov 6, 2008 | 10:16 AM
Since you will be adding that extra weight, I would suggest the OME 751 front springs along with the 762 rear springs, HD OME shocks and their steering stabilizer.
If you are at all mechanical, you can install it on your driveway in about 3 to 4 hours.
Old Oct 12, 2009 | 03:04 PM
antichrist's Avatar
jerseymike, do you ever post anything remotely related to the thread you're posting in?
Old Nov 4, 2009 | 10:35 AM
yupathi's Avatar
I accept with information: Since you will be adding that extra weight, I would suggest the OME 751 front springs along with the 762 rear springs, HD OME shocks and their steering stabilizer.
Old Nov 4, 2009 | 01:54 PM
That is what I am currently running, slightly firm but with dual batteries front and rear custom bumpers a winch and sliders, I wanted the extra support.
If you don't want that firm a ride, use the 779 front coils with the 762 rears.
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
caspian
Feb 19, 2011 06:41 PM
majrmike
Oct 9, 2007 03:13 PM
studlee
Aug 8, 2006 10:29 PM
