Safari Roof Rack Repaint
Old Mar 26, 2012 | 05:45 PM
wheelgarage's Avatar
Rust Oleum Professionals Paint....ummm....going to check that out.
Old Mar 28, 2012 | 10:49 PM
Mountain Goat's Avatar
Seems they now make a UV-resistant POR-15 paint. I'd try that in a heartbeat, stuff lasts forever. Won't even come off your skin...
EDIT: POR-15® is sensitive to UV light (sun) and must be top coated for prolonged exposure to sunlight.
Top coating is not required for areas not exposed to sunlight.
http://www.por15.com/POR-15/productinfo/1GB/
They do sell a top-coat though. All their stuff is pricey but lasts forever when installed as designed. No I don't work for them.
Old May 24, 2012 | 08:39 PM
ColoDisco's Avatar
I just painted my rusty brown church with POR 15.
Old May 24, 2012 | 08:53 PM
Did you use a topcoat?
Old May 24, 2012 | 09:55 PM
ColoDisco's Avatar
No, but I am planning on repainting this winter with a lighter color, mostly because I am adding rotopax to my rack for extra fuel.
Old Jun 13, 2012 | 09:47 PM
ekahi_1's Avatar
i was thinking of sanding every thing down and using some of the DIY roll on bed liner from the auto parts store.
Old Sep 22, 2012 | 04:11 PM
Todd-Squad's Avatar
8th Gear
Default I just repainted my Ladder on the back door of my D2
I used Rustoleum Black Satin Finish. It matches the original powder coat exactly. I've painted lots of car and motorcycle parts that are exposed and had great luck with Rustoleum. The suggestion about room temperature is a good one. I always apply several coats. Many thin coats will look better than one or two thick coats. Also if you can find some 400 or 600 grit sandpaper and wet sand between coats. Lastly, if the part is small enough, stick it in your wifes oven for a couple of hours at very low heat. In the case of my ladder, I did it in July, and just hung it in the sun all afternoon.
Old Sep 23, 2012 | 08:18 AM
From a number of people I have spoken with, this last year, their Professional paint is a big step up over the standard Rustoleum.
Old Sep 23, 2012 | 09:24 PM
XCELLER8's Avatar
fwiw...I've had really good results with the Rustoleum spray on bedliner....easy, durable, nice look.
Roverboy3766
Dec 6, 2007 03:42 PM
Disco2Guy
Sep 13, 2007 11:29 PM
Brad S1
Sep 23, 2006 11:10 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
