Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Single Turbo Rover V8 Triumph TR7 Build by The Wedge Shop
Old May 9, 2012 | 09:51 AM
thewedgeshop's Avatar
4wd High
Default Single Turbo Rover V8 Triumph TR7 Build by The Wedge Shop
I am have been in the process of building a Single Turbo Rover V8 setup for my 1977 TR7 FHC.
The motor will be a stock rebuilt 3.5 Rover with std compression (8:1) which is ideal for the turbo application. I will be using Cometic head gaskets,in which the heads have been shaved down to accommodate the extra thickness of these gaskets. Erson cams has designed a special grind pattern for the application that will be suited for the turbo application with power from 2500-6500. A Holley 650 blow thru carb from The Carb Shop setup specifically for my setup. The Holley will sit on top of a harcourt single plane intake manifold. The setup will be intercooled with 2.5in piping. I will be using rover manifolds that will push a single Garret To4b turbo designed to run efficiently at 10-15lbs of boost
The transmission will be a stock rebuilt Rover trans LT77. The cars already has The Wedge Shop Mustang rear end conversion and all the other goodies.
I will update the thread over time with my progress. I plan on making the turbo setup into a kit in which anyone can bolt on their stock 3.5 with no modification and push 250Hp to the wheels.
P.S. The end goal for this car is to become a GROUP 44 Replica
Here are some more specs on the setup.
Specs on Driving
Street car
1 -5 drag passes a year
Driven to cars shows 600+ miles
6300k Redline
Drive ability is important
300-350WHP Target
Quick specs on Motor:
215 cubic inch
Aluminum Block
Aluminum Heads
Fresh rebuild
ARP hardware
Cometic Headgaskets
Makes 210hp in NA form
Specs
Rover 3.5 (215 cu in)
8:1 compression
93 Pump Gas
ARP head studs, main studs
Stock Heads
Erson TQ20 on a 112 (478 lift, 214 duration at .050)
Cast pistons, rods
Single plane intake
Blow thru Carb (Holley 650)
10-15psi max
Mallory 6 Box (Boost timing retard functionality run off MAP sensor 1* timing pulled per 1LB of boost)
Intercooler Core Size 11"X12"X3" Overall Size 18"x12"x3" 2.5" Inlet & Outlet 3" Core
3 in Mandrel bent exhaust from Downpipe back
160* thermostat
Mallory SS distributor 24* advance with 10* static advance
1 PTE 46mm External Wastegate
1 Tial 50mm BOV
Garret to4e 60 trim .58 A/R O Trim T4 exhaust housing with 3in Vband outlet
Thanks
Clint
The Wedge Shop
The Wedge Shop - Fast. British. Reliable
Fast. British. Reliable.
Old May 10, 2012 | 04:18 PM
RoverMasterTech's Avatar
Blow through sucks... Go for a lucas intake manifold and megasquirt EFI you can trigger off the coil. Also you could pull the velocity stacks off, make a custom plenum and put a disco 2 throttle body on the front of it. Other than that its bad as hell.
Old May 11, 2012 | 06:54 AM
4wd High
Thanks for the advice. The decision to go blow through was partly price, partly the ease of installation and some local knowledge around the setups. Should be running in a few weeks and I will follow up.
Thanks
Clint
Old May 12, 2012 | 09:28 PM
Danny Lee 97 Disco's Avatar
Awesome project!
Old Aug 9, 2012 | 11:16 AM
4wd High
Finally got the car running correctly. The car runs and drive great with excellent throttle response and driveability. Below are a few videos that demonstrate that. As soon as I have some dyno numbers I will let you know.
Had to change out the carb hat and for the time being cut a hole in the hood.... Not my first choice, but had to get it to The Roadster Factory show and not having a hood that closes was not an option.
Here is a quick 3rd 4th gear pull. Car runs strong and am expecting 275-325whp when I get it back to the dyno.
Getting into Boost
Driveability and acceleration
Thanks
Clint
Old May 24, 2013 | 11:56 PM
4wd High
Car made 278whp & 305wtq @ 10psi. Still has more in it with some added boost and timing.
Specs on car
Clint's Coupe - The Wedge Shop
Dyno Sheet
http://www.thewedgeshop.com/uploads/..._runs_5.13.pdf
Video below.
http://www.youtube.com/watch?v=_HJI_wSxQIE&feature=youtu.b
Spike555
Oct 20, 2019 09:10 PM
raeuspius
Oct 10, 2014 09:43 PM
AnnelieseMae
Feb 12, 2009 05:44 PM
viper205
Jun 17, 2008 07:44 PM
nomad64
Jul 27, 2006 09:50 PM
