defender diesel 1972 startproblems
Old Oct 27, 2010 | 03:23 PM
nightrider75's Avatar
Default defender diesel 1972 startproblems
Hi,just bought a landrover defender diesel from 1972 and it have stand still nearly one whole year.
The old owner told me that the battery was,nt good so i bought a new batery today and starter go,s good but its not starting and i like to drive her to the garrage and get a new eu kontrol on her whitout to much work.
is it a option to dregg and jumpstart her?
please help me.
tanx
Old Oct 27, 2010 | 04:45 PM
antichrist's Avatar
Defenders weren't build in 1972, so I assume it's a Series Land Rover. So yes, it would be fine to try to start it by rolling it, assuming the engine isn't seized.
If it were mine I would leave the fuel shut off, put it in gear and have someone tow you around some to get the oil flowing in the engine before you then turn on the fuel to try to start it.
Make sure the coolant level is good before starting it.
Old Oct 27, 2010 | 09:28 PM
If you have excess water or air in the fuel lines it will not start, and sitting for a year both of those are very possible.
Old Oct 28, 2010 | 05:14 AM
antichrist's Avatar
good point Spike. Unfortunately I neglected to mention the obvious (to me) to drain and replace with new fuel.
After a year the diesel is likely full of bacterial scum anyway, unless a bio-cide was added.
Old Oct 28, 2010 | 07:50 AM
Fantastic!!!
We roll the car for some meters and just in the second gear.
after returning start direktly!!!
Lots of white smoke and little bit black for 15 minutes.
Now it runs but have to chance the clutch but the main problem is done thankx alot!!!
Regards
Old Oct 28, 2010 | 04:17 PM
Glad to hear you got her running.
Old Oct 28, 2010 | 10:18 PM
Danny Lee 97 Disco's Avatar
Does it have a hand crank for the engine? A friend of mine has an ex-MOD series that does have a hand crank as well.
Old Oct 29, 2010 | 07:26 AM
antichrist's Avatar
The diesels had hand cranks as well, but it's not particularly fun to do because of the high compression of a diesel.
My Series petrols I hand cranked on a few occasions. One of my 6cyl I did for over a month in a Vermont winter in '80 because I was broke and couldn't afford a starter solenoid.
Old Oct 29, 2010 | 07:16 PM
Its a bitch hand cranking a engine petrol or not, we had a 1936 Allis Chalmers with hand crank and if you forgot to charge the battery you hand to hand crank it.
Do that once or twice and you would'nt forget to hook up the battery charger ever again. (it didnt have a alternator, it ran off a magneto but it also had a electric starter so the battery was used for starting only)
roverdisco1017
May 5, 2021 09:56 AM
jacnac4
Feb 3, 2015 01:47 PM
Western Lithics
Apr 8, 2012 11:52 AM
performance_innovation
Sep 7, 2011 07:08 AM
missyq2323
Sep 16, 2009 11:32 AM
