ignition key snapped off in ignition
Old Sep 10, 2013 | 02:47 PM
will rocket's Avatar
Default ignition key snapped off in ignition
hey fellas my key snapped off in my ignition and i dont have any money for a lock smith, it snapped in two places. I was able to remove the middle section but cannot get the tip of the key out to use my spare key and cant find a place that carries these keys or i would just cut my spare down and use that, any way to hot wire these this for the time being? i really need help and im pretty broke and ghetto rigging solutions?????
Old Sep 10, 2013 | 03:11 PM
gprtech's Avatar
Here are key blanks
Key Men - Catalog #: X239
Old Sep 11, 2013 | 08:57 AM
cosmiccharlie's Avatar
Don't cut your spare key!! Most likely the end of the key that is still in the ignition has worked it's way deeper into the switch, so a cut key will not mate up to it.
Same thing happened to me and a locksmith could not extract the piece that was in the ignition. If you are handy, this is the write up i followed to remove the ignition, disassemble the ignition and remove the key.
https://landroverforums.com/forum/di...ock-fix-35422/
The first step of this write up says us a sharp chisel and hammer to remove the two bolts securing the switch to the column, but I was able to do it with a pair of vicegrips. I replaced them with phillips screws for ease of removal if I ever had to do it again.
Old Sep 11, 2013 | 08:58 AM
Also once you have the switch removed from the truck you can start it with a flat blade screwdriver. I drove mine like that for a couple of days.
Old Sep 12, 2013 | 06:23 AM
thanks guys but before getting to read these replies, i went to go remove the cylinder and i noticed the shear pin had already been snapped and a zip tie holding it place. when i pulled the pin and removed the cylinder it started falling apart, tumblers were falling out ect. so i removed all tumblers reassembled and wallah starts right up with anything that fits the hole. now im gotta go find an new cylinder.
slskier88
Dec 18, 2013 01:43 PM
steveo2000
Sep 1, 2011 03:14 PM
wynhd
May 3, 2011 04:12 PM
LR03NJ
Jun 16, 2010 10:28 AM
cowtown
Dec 15, 2009 10:25 PM
