Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Off Topic
Register Forgot Password?
Old 03-17-2010, 02:44 PM
Senior Member
Default Head light question
One of my other cars is a 2004 Lexus rx 330 and there seems to be a leak somewhere in the front headlight which is letting moisture in. It condenses on the inside so there are a crap ton of little water droplets on the inside of the glass. Anyone have an idea how to fix this? Lexus said that it was not covered by my extended warranty and there is no way i am going to pay for a new one cus thats a grand i could put into the disco.
thanks for the help.
__________________
2000 Discovery 2
110,000 miles
Kenwood DVD Navigation, Spintec cat back (SOLD)
Shoppin for a D1, I have a LB7 Duramax & Allison that are looking for a new home
-I hate hippies... I hate'm-
Old 03-17-2010, 04:08 PM
yloDiscoII's Avatar
Senior Member
Probably has a crack somewhere...Pull off the assembly, dry it out and locate the crack. You can most likely seal it up with some epoxy. If it's a crack in one of the seals, use some RTV after you get it all dried out.
You can also check out eBay, CL or a junk yard if you have to get a new assembly. I'm sure the "stealership" name holds true for Lexus as it does for Rover.
__________________
Rob
2002 DII Kalahari (139K)
“We do not accept that ours will ever be a nation of haves and have-nots; we must always be a nation of haves and soon-to-haves”
Old 03-23-2010, 10:23 AM
Send a message via Skype™ to Disco Mike
First, you need to look and see if there is a drain pipe from your head light assembly that is plugged?
If not, then remove the light housing assembly, remove the light element and drain and dry out the light. Inspect it for a crack or bad seal and silicone it tight.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
