Recommended Fluids for 93 RRC
Old Nov 22, 2011 | 01:52 PM
cminer's Avatar
Default Recommended Fluids for 93 RRC
Got a buddy that needs to do pretty much everything. Any recommend diff/transfer case fluids for this model?
Dextron III for trans?
Preferred coolant for this model and anything else that needs to be changed on vehicles first service with the current owner/113k miles.
Old Nov 22, 2011 | 07:26 PM
Eniam17's Avatar
Here is an article from a well respected Rover and foreign auto specialist covering fluid changes.
How Rovers get here, driveshafts and fluids
Old Nov 22, 2011 | 07:53 PM
Here's pages from the RAVE, the factory manual on the truck. Free download below of whole set, includes electrical diagrams, owners manuals, shop manuals, etc.
Note that power steering and transmission use ATF. Select oil by climate, 10W30 is only good from -4 to +50 F, as an example.
File Type: pdf
Old Nov 22, 2011 | 07:56 PM
cminer's Avatar
Thanks for the article.
So Synthetic Dexron ATF for the transfer case.
Dexron 3 for the transmission.
75-90 Gear oil for the diffs.
Old Nov 22, 2011 | 08:01 PM
cminer's Avatar
I read the Rave docs but wanted to know if there were changes because those docs appeared to be almost 20 years old now.
Old Nov 22, 2011 | 08:02 PM
That would depend on transfer case fitted. Borg Warner, yes. But an LT230 uses same oil as diffs. Older models and owners report use of 85W140 synthetic quiets the older high miles cases and diffs.
Old Nov 22, 2011 | 08:08 PM
No dexcool please on coolant, green is good, 50/50 premix Peak is hard to mess up. Radiator is a copper / brass affair, if calciumed up may be a candidate for acid flush and rod out by an indy radiator shop, can be had for $75 or so, you carry radiator in.
Many owners like the diesel rated oils for extra cleaning, and a high miles low spending PO is a good reason to use them. Shell Rotella is one brand, cheap, easy to find.
20 years old? Just getting broken in. I must say I prefer the older trucks. Parked by a newer Tahoe today, with electric running boards that retract into the body when the door closes. Too much fru-fru....
WNYErikDiscoII
Nov 7, 2013 09:32 AM
Lincoln Tarantino
May 2, 2012 11:20 AM
Paul Grant
36
Mar 14, 2012 07:59 PM
DiscoRover007
May 8, 2011 04:24 PM
DDLR3
Jan 6, 2008 08:35 PM
