Recommended differential fluids?
Old May 8, 2011 | 01:25 PM
DiscoRover007's Avatar
Default Recommended differential fluids?
So I just changed the gear oil in my t-case and I'm considering changing the differential fluid as well as I will be away from the Rover for about a month and it has not been changed since purchase.
Considering the mileage of the truck(130,000) should I consider using a heavier weight? Synthetic vs regular? Etc..
Thanks
Old May 8, 2011 | 01:53 PM
antichrist's Avatar
What the owners handbook lists is fine.
Synthetic or dino oil, either one, is fine. Personally I use cheap dino and change it more often. If you rarely off-road anywhere wet then the cost of synthetic isn't cost prohibitive.
Old May 8, 2011 | 04:24 PM
What he said. ^
I use 85w-140 el chepo gear lube from Tractor Supply Co. and change it once a year.
Or soon if water gets in after a 'froadin' trip.
cminer
Nov 22, 2011 08:08 PM
werldcup
Feb 7, 2008 04:15 PM
DDLR3
Jan 6, 2008 08:35 PM
D2 2003
Mar 16, 2007 11:31 AM
wildhorses
Oct 16, 2005 10:36 PM
