Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 07-05-2011, 12:49 PM
Junior Member
Default illuminatin cluster?
Hello! a have a Range rover from 2000 whit a engine 2,5TD but d,ont have a illumination in a cluster. Please help me!
Old 07-10-2011, 12:54 AM
LRScott's Avatar
Senior Member
Do you mean the information display or the whole cluster? The information display (where it displays the mileage etc.) have little lights that can be replaced without too much effort.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 07-10-2011, 02:22 AM
Junior Member
on th 2010..will that instrutment cluster fit in 03-05 or 06-09 plug n play
Old 07-16-2011, 12:30 AM
Member
One light in my 2000 RR information display went out last week. Can you point me to directions on replacing them or give me a couple of pointers? Thanks.
__________________
Don't spill the beer!
ol' Blue, 2000 RR HSE 116K miles
Old 07-16-2011, 02:09 AM
Member
The NEW range rover (post 2002) cluster ave to be coded
unfortunately no straight swapping here
Old 07-16-2011, 02:12 AM
Member
2000 my RR Yes there are 3 little bulbs that illuminate the cluster
the cluster ave to be removed to replace them
easy enough
Need to remove cluster surround
remember about two screws you can only see when pull and drop steering column (just behind it)
Old 07-25-2011, 01:37 AM
Member
Thanks for that tip. I would have missed those screw.
__________________
Old 07-25-2011, 03:36 AM
Member
I found this link: LCD Backlight Repair
as a great instructional reference on how to replace these bulbs. I hope this links helps others as well.
__________________
Tags
2000, cluster, furum, information, land, range, repair, replacing, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
