Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 10-18-2011, 09:00 AM
Junior Member
Default Range Rover classic LWB not starting
My Rangie has been ever faithful until recently when it started taking two three attempts to start as if it wasn't getting fuel. I changed the fuel filter and now it won't start all. Checked fuel pressure and it is adequate, when I checked the coil wire it had a intermittent spark. So I changed the plugs, wires, rotor, dist cap, and ignition coil. She still fails to start? Any suggestions?
Old 10-21-2011, 07:22 PM
LRScott's Avatar
Senior Member
I don't have much experience with the classic, I might suspect the EFI is malfunctioning though... Here is a neat little site for Classic Rangies, you might find it helpful. Range Rover Remedies
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 12-25-2011, 01:45 AM
Junior Member
Well after a few more accessory replacements I'm up and running again. I changed out the electric module piggy backed off the distributor, and the magnetic pick-up. So after all the attempted starts I burned up my starter, so after finally replacing the starter I'm back out on the trail.
Old 12-25-2011, 12:54 PM
jafir's Avatar
Senior Member
You may want to relocate the amplifier from the distributor to some place not so hot.
ICM
Land Rover made a kit to do this, but it's expensive.
__________________
______________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
Old 12-26-2011, 07:32 AM
Junior Member
I did see a few kits online to relocate the module. It is in a precarious place for heat and located directly under the upper radiator hose. I did notice a pin hole leak off of a vulcanized temp sensor on the upper hose that soaked the module and probably fried it.
Old 01-01-2012, 12:36 PM
Junior Member
Tags
amp, classic, enthusiasts, forum, gm, ignition, land, lwb, module, produced, range, remedies, rover, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
