Range Rover classic LWB
Old Oct 18, 2011 | 09:00 AM
Trex67's Avatar
3rd Gear
Default Range Rover classic LWB not starting
My Rangie has been ever faithful until recently when it started taking two three attempts to start as if it wasn't getting fuel. I changed the fuel filter and now it won't start all. Checked fuel pressure and it is adequate, when I checked the coil wire it had a intermittent spark. So I changed the plugs, wires, rotor, dist cap, and ignition coil. She still fails to start? Any suggestions?
Old Oct 21, 2011 | 07:22 PM
LRScott's Avatar
I don't have much experience with the classic, I might suspect the EFI is malfunctioning though... Here is a neat little site for Classic Rangies, you might find it helpful. Range Rover Remedies
Old Dec 25, 2011 | 01:45 AM
Trex67's Avatar
3rd Gear
Well after a few more accessory replacements I'm up and running again. I changed out the electric module piggy backed off the distributor, and the magnetic pick-up. So after all the attempted starts I burned up my starter, so after finally replacing the starter I'm back out on the trail.
Old Dec 25, 2011 | 12:54 PM
jafir's Avatar
You may want to relocate the amplifier from the distributor to some place not so hot.
ICM
Land Rover made a kit to do this, but it's expensive.
Old Dec 26, 2011 | 07:32 AM
Trex67's Avatar
3rd Gear
I did see a few kits online to relocate the module. It is in a precarious place for heat and located directly under the upper radiator hose. I did notice a pin hole leak off of a vulcanized temp sensor on the upper hose that soaked the module and probably fried it.
Old Jan 1, 2012 | 12:36 PM
mikieman's Avatar
reflextuning
May 18, 2021 11:22 AM
GoldDiscoII
Jan 10, 2010 04:42 PM
LANDROVER LUKE
Apr 14, 2009 09:22 AM
RangeRovering
Nov 3, 2007 01:39 PM
das
May 26, 2007 10:42 PM
