Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 09-11-2011, 11:16 AM
Junior Member
Default Timing chain kit.
Hey guys,
New here, hope this is in the correct place. I just got a '97 as a project. I was replacing the crankshaft seal when I decided, why not just drop the oil pan and remove the oil pump housing to check the timing and components.
So the chain is very loose and I am going to replace the gear set and chain as well. I came across this kit but it looks like it is for '99-'02 P38's only. Is there something like this compatible with the '97? It looks like just the oil pan gasket that is not compatible with my year, I'd hate to just have a wasted part. Thanks in advance.
Timing Chain Kit (BOSCH Engine) | Land Rover Engine Parts at RoverParts.com
-Marc
__________________
-(void)
Old 09-11-2011, 01:33 PM
Send a message via Skype™ to Disco Mike
Not sure as to the specific part number chain set to us, just wanted to suggest you also replace the oil pump if you are at 140,000 mile or above.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 09-11-2011, 01:37 PM
Junior Member
Thanks for the advice Disco Mike. I will look into replacing the pump as well since I am at 167k. Do I need to replace the entire housing or just the oil pump gears?
__________________
-(void)
Old 09-11-2011, 01:52 PM
Senior Member
__________________
Old 09-13-2011, 01:48 PM
Junior Member
Thanks Savannah, that was a good read.
I just got finished replacing everything last night. Going to drop the radiator back in after work and fire it up and see what happens.
__________________
-(void)
Tags
02, 2006, chain, d1, discovery, guide, kit, land, life, p38, range, replacement, rocer, rover, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
