Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 11-16-2011, 10:46 AM
Junior Member
Default Transmission Computer
Anyone know a good source for a transmission computer for my sick 2006 RR SC? Just got the transmission rebuilt, but I am now told I need a new computer
Old 11-17-2011, 05:00 PM
Senior Member
its the whole valve block inside the tranny they obviously didnt rebuilt it right.
Old 11-18-2011, 03:53 PM
Junior Member
Having transmission trouble on my 2006 RR SC as well. Have been told by the dealer it is a $5,000 job. They say Range Rover says never to reboot the programming as it will make it worse? Have no idea what they are talking about.
Old 11-20-2011, 08:58 AM
Senior Member
Dear god, just repgm the ecu and the Tcu together it will fix most of the problems.
unless the transmission cooler went on the SC then it would kill the transmission.
What exactly is it doing?
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 11-21-2011, 10:07 AM
Junior Member
It shifts like a kick when you slow down at a stop. The reprogramming sounds like a no brainer to me but the dealer says it's a one time shot and land rover doesn't recommend as it will cause the transmission to fail. Maybe a different dealer would have a different answer.
Old 11-21-2011, 04:06 PM
Senior Member
really a dealer said this? 99% of driveability issues are software updates either for the engine control module or transmission control module. there are several bulletins regarding issues with shifting. just have them check if there is an updated patch file. easy as that takes couple minutes to do
Old 11-22-2011, 10:22 AM
Junior Member
Ok it's scheduled to go in to the shop for the 90,000 mile inspection. I'll spend time with the actual mechanic to see what programming is available and what patches are available. I'll also check changing transmission fluid and filter, along with the cooling to see if there are any issues. I'll post the results . Happy thanksgiving
Tags
2006, computer, computers, landrover, programming, range, rover, tcu, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
