Transmission Computer
Old Nov 16, 2011 | 10:46 AM
jnorm's Avatar
Default Transmission Computer
Anyone know a good source for a transmission computer for my sick 2006 RR SC? Just got the transmission rebuilt, but I am now told I need a new computer
Old Nov 17, 2011 | 05:00 PM
socalrovershop's Avatar
its the whole valve block inside the tranny they obviously didnt rebuilt it right.
Old Nov 18, 2011 | 03:53 PM
pkruger's Avatar
5th Gear
Having transmission trouble on my 2006 RR SC as well. Have been told by the dealer it is a $5,000 job. They say Range Rover says never to reboot the programming as it will make it worse? Have no idea what they are talking about.
Old Nov 20, 2011 | 08:58 AM
Rovin4life's Avatar
Dear god, just repgm the ecu and the Tcu together it will fix most of the problems.
unless the transmission cooler went on the SC then it would kill the transmission.
What exactly is it doing?
Old Nov 21, 2011 | 10:07 AM
pkruger's Avatar
5th Gear
It shifts like a kick when you slow down at a stop. The reprogramming sounds like a no brainer to me but the dealer says it's a one time shot and land rover doesn't recommend as it will cause the transmission to fail. Maybe a different dealer would have a different answer.
Old Nov 21, 2011 | 04:06 PM
really a dealer said this? 99% of driveability issues are software updates either for the engine control module or transmission control module. there are several bulletins regarding issues with shifting. just have them check if there is an updated patch file. easy as that takes couple minutes to do
Old Nov 22, 2011 | 10:22 AM
pkruger's Avatar
5th Gear
Ok it's scheduled to go in to the shop for the 90,000 mile inspection. I'll spend time with the actual mechanic to see what programming is available and what patches are available. I'll also check changing transmission fluid and filter, along with the cooling to see if there are any issues. I'll post the results . Happy thanksgiving
cheqbay1997
Jun 11, 2014 10:24 AM
02range
Sep 15, 2006 02:39 PM
Deutsch100
Aug 4, 2006 11:44 PM
B5B6B4D2
Jul 20, 2006 07:58 AM
JTravis
Dec 31, 2005 11:00 PM
