Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 09-06-2011, 10:43 AM
Junior Member
Default using oil
have 4.2l RR Classic New heads recently, check or replaced all hoses (vac). Will go through a 1 quart of in a 100 miles or less. No oil on spark plugs. Really smokes bad over 2.5 grand. any help Thanks
__________________
1993 Range Rover
2004.5 GMC Durmax
28' flatbed gooseneck trailer
91/2' slidein camper
rolling over another rock
Old 09-06-2011, 11:10 AM
Senior Member
If smoke is out the rear view mirror, as opposed to only out the tail pipe, could be external gasket leak on to exhaust. If coming from under the vehicle it may leave spots on rear door and glass. If out the tail pipe that sorta narrows it down to the head gaskets or exhaust valve seals/guides. Should not be rings, since you don't see it on plugs. Compression test to locate faulty valve (tells you which side, obviously we can't open just one cyclinder ). If a commercial shop did the work, there should be some sort of warranty?
Valve cover gaskets need snugging up? PCV (american name for it) system plugged up (my Disco has a squiggley piece of plastic baffle in the valve cover that if clogged is supposed to make oil come out elsewhere).
Don't forget to check oil cooler/oil cooler lines if so equipped. You could have an oil leak AND problems from something else at higher rpm.
Reason I mention exterior leak is that I had one when first got mine, was doing about 75, saw smoke, feared the worst, slowed down, it went away, found leak.
__________________
Old 09-06-2011, 04:47 PM
EUR Mechaniker's Avatar
Member
its very common for these to leak. if your only having the problem above 2500 its related to the higher oil pressure than you get at idle. if its just out the tailpipe it could be the pcv system, valve seal (were these done with the heads?) , could be rings, or head gasket kinked during installation as well...
Old 09-06-2011, 08:52 PM
Senior Member
If rings, would that show up as fouling on the plugs? Lotta oil going somewhere. I have a Mercedes that used to go through 1 quart every 500 mles with an external leak from valve covers, HG, and the O-ring on the oil level float switch (yep, they have a light that turns on when you are a quart low). Doing that in a hundred miles would have to leave a trail down the driveway to the Ponderosa.
Was hoping not rings so if he had any warranty issue on the HG it might be covered.
__________________
Old 09-06-2011, 10:39 PM
Member
Rings will not necessarily foul plugs... if its cylinder wall splash it will just burn blue from the tailpipe... leakdown test should show rings ... anything with the head should be warrentied though if done by a professional... so start your checks there...
Old 09-07-2011, 07:29 PM
Junior Member
Thanks all for your in put. Today we took valve cover off checked compression, the compression was good but putting air in cylinders just went right into crankcase not good. Anyway ring are bad compression good at low rpms. Will just have to drive until it quits.
__________________
1993 Range Rover
2004.5 GMC Durmax
Old 09-07-2011, 09:40 PM
Member
will be sooner rther than later if you ignore bad rings...
Tags
gasket, head, land, oil, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
