Using battery connections to clear codes
Old May 15, 2006 | 12:09 AM
rovernbama's Avatar
8th Gear
Default Using battery connections to clear codes
I was chatting with a guy today who said that if you want to clear all the codes from the computer's memory (like if you have replaced the ABS modulator yourself and need to clear the fault codes) that you can do this by disconnecting both battery cables, waiting five seconds, then touching the battery cables together? Any thoughts on this? Could it do more harm than good? Oh, and how can you find out your radio codes? Is there anythign else that disconnecting the battery will screw up?
Old May 15, 2006 | 12:17 AM
esaycho's Avatar
Default RE: Using battery connections to clear codes
As soon as u disconnect the negative terminal the computers memory will become corrupt, it will clear all the codes and will relearn idle and some other functions, to find the radio code u need to call or go to the dealership, if u call u need to give them ur VIN number and they may ask for proof of ownership. I know that on the Range Rover u need to also roll down and up the windows so it can re learn the one touch/anti-trap, as well as open and close the sunroof, not sure about a Disco's windows though.
Old May 15, 2006 | 12:21 AM
ORIGINAL: rovernbama
That was a scarey person you spoke with, do your self a favor and never let him near your truck.
If your truck has OBD2 you can only ckear codes with a good scanner or test book, same with ABS, scanner or test book and there aren't many scanner that can touch a Rovers ABS.
As for touching the cable ends together, buy a new alternator first cause that is one of the best way to fry the diodes.
Radio codes, if the truck is not too old can be gotten from Rover only. Sometimes a dealer will write it in your trucks service folder, but not always. Some selling dealers will note the radio code in your trucks sales folder.
By the way, did your friend work as a mechanic at Sears?
Just kidding, I think.
Mike
Old May 15, 2006 | 03:24 AM
mikemeyer0's Avatar
leave battery disconnected for hour or so may or may not clear the codes, either way you will have to enter the security code back into the radio if you disconnect at all. tapping the cables together will do nothing for ya.
Old May 15, 2006 | 01:20 PM
ORIGINAL: mikemeyer0
Only on a OBD1, OBD2's have great memorys.
Mike
Old May 15, 2006 | 02:51 PM
rovernbama's Avatar
8th Gear
Default Car stereo shop
This guy installs car stereos at a local car stereo shop. Maybe even worse than sears.
Old May 15, 2006 | 03:03 PM
Default RE: Car stereo shop
Oh the radio shop at Sears, I think I may have seen him there.
Scarey thought.
Mike
JoeLena
Oct 20, 2014 08:39 AM
robgusto
Aug 24, 2013 05:03 PM
srockrae
Oct 6, 2012 11:19 AM
tbesselman
Apr 23, 2012 07:54 AM
VikingDiesel
Jun 10, 2009 09:06 AM
